Map Viewer Questions
1182
10-13-2021 09:28 AM
ZorbaConlen1
Hi. Here are a few questions I have after using the new Map Viewer app.
  • For popups, is there an html editor mode where one can write and edit the html directly? Not seeing it.
  • I found that when you apply effects to layers, it's not honored in the legend. Is this in the works for future release?
  • Filtering on layers: when you add multiple conditions, they are evaluated with an 'AND' operator and there is no way to specify 'OR'. So, its conditon 1 and conditon 2, whereas sometimes one might want to apply it like condition 1 or condition 2. It's kind of limited. Wondering if this is going to be enhanced for more flexibility.
  • Effects and blend modes applied to basemaps: this is cool. I used this article to create a cool highlighted area of interest for my map - https://www.esri.com/arcgis-blog/products/arcgis-online/mapping/highlighting-areas-effects/. The problem I'm noticing is that the effects are not persistent when an end user switches to a different basemap. All basemap effects are lost at that point. Is there a way to persist these settings to they remain in effect?
Thanks
Tags (1)
RussRoberts
Esri Notable Contributor
- Popup html editor is on our roadmap hopefully coming in an update soon.
- Legend support for effects is planned for December
- You can switch to AND/OR using the dropdown on the filter panel "Match all or match at least one". This works on the entire expression or the set.
- basemaps have different layers we cannot persist the effects across but appreciate this feedback!
RussRoberts
