Map Viewer Configure form Info Box - Code
1104
02-19-2025 05:43 AM
ablum
Hi, I'm trying to figure out how to use the code function in the Info box when configuring a form. I've pasted the text I need but would like to add different font colors and new lines. I've clicked the code button and typed the HTML needed but it just shows the HTML text instead of updating the actual text. Any help would be appreciated.
AustinAverill
You just have some syntax errors like mismatched quotes occurring here. If you are going to edit everything in HTML, it should also all be attributed appropriately -
<!-- Example -->
<div>
   <p>First Section</p>
</div>
<div>
   <p style="color:red"> Red Section</p>
</div>
<div>
    <p>Final Section</p>
</div>
This code would translate to appear as:
First Section
Red Section (This would be red except for this forum doesn't support the style attribute)
Final Section
beeshiels_galway
I have been trying this out with HTML code and I tried @AustinAverill code above but nothing is working. Even though there is a code button I can't find any documentation or example of it working. Has anyone got this to work in the smart form?
