Map rejects hosted feature layer after overwrite
20266
33
12-21-2022 01:13 PM
RandyMcGregor3
I have a hosted feature layer in ArcGIS Online that I need to periodically overwrite. It appears in four maps. When I overwrite it, all layers sourced to this feature layer become disconnected with an error message 'An error occurred loading this layer.' There is nothing wrong with the layer. No fields change. The source GIS layer is the same each time (new features are swapped out for old - and that's when I need to overwrite the layer.). I reload it and reconfigure it when this happens. This is time-consuming.
Does anyone know what causes this? I overwrite hosted feature layers regularly and this is not a normal occurrence.
Any suggestions would be appreciated. This is very disruptive to an important workflow.
Thank you,
Randy McGregor
EmersonCardenasSachica
i already have now two problems...
One HFL fail after overwrite web layer from arcgis pro to AOL ...
and in other the HFL overwrite well from arcgis pro to AOL but the paralel view of the HFL failed!
so really dont know what are i'm doing worng
RhettZufelt
MVP Notable Contributor
You can use ArcGIS Online Assistant to update the URLs of the services used in the map(s).
Haven't tested this to see if it keeps all the popups, labels, etc. but you can change the layer id's as well in the URL here.
R_
Thanks RhettZufelt ... this solved my problem with the MAP and save me to remake symbology colors!!!... i'm so happy!!
as this is step by step...
the next problem is in the dashboard... now I can see the map and his colors, but the data in the "body"  and "sidebar" of the dashboard still broken (yellow triangle) this data doesn't came from the layer map data.. this came from the "Stand-alone layers  data"  ... any suggestion for repair?
RhettZufelt
Have not done much with dashboards yet.  But, on occasion, with the few I have made,  I have seen the yellow triangle and just had to re-connect the data source in the dashboard widget.
R_
