Map not displaying getting errors from dojoLoader
6429
6
12-26-2012 05:28 AM
ChandraMiller
My map is not displaying in ArcGIS Online.  The last time I checked it was on 12/20 and it was working in ArcGIS Online.  I just got back from vacation and the map is not loading at all.  Here is the link to the map http://maricopa.maps.arcgis.com/home/webmap/viewer.html?webmap=4dd4b8b8195846f3a2e54bf876800508.
Here are the errors I am getting from the Chrome Developer Console.  I also attached a screen shot of how the web map looks on iPhone 4s.
Failed to load resource: the server responded with a status of 404 (Not Found) http://d3w50ib5d2uy0g.cloudfront.net/cdn/2203/js/esri/nls/base_ROOT.js
Error
dojo.js:15
src: dojoLoader dojo.js:15
info:
Array[2]
dojo.js:15
. dojo.js:15
Failed to load resource: the server responded with a status of 404 (Not Found) http://d3w50ib5d2uy0g.cloudfront.net/cdn/2203/js/esri/nls/arcgisonline_ROOT.js
Error
dojo.js:15
info:
Array[2]
dojo.js:15
. dojo.js:15
Failed to load resource: the server responded with a status of 404 (Not Found) http://d3w50ib5d2uy0g.cloudfront.net/cdn/2203/js/dojo/dojox/gfx/svg.js
Error
dojo.js:15
info:
Array[2]
Was there an update/change that I am not aware of?  On the 20th my map was not opening in ArcGIS Explorer.  I was getting an unsupported webmap version number (1.7) error. I have tried clearing my browser history in IE8 and Chrome and everything I do is still giving me an error when I try to open up the map in ArcGIS Explorer Online.
ChandraMiller
This morning my map is working fine the all the internet browsers and the ArcGIS ESRI app but the web map on my phone is giving me problems.  I attached a screen shot of errors that are displaying.  The map displays underneath 7 errors that read
"DEPRECATED: dojo/io/script Use dojo/request/script. -- will be removed in version: 2.0."
"DEPRECIATED: dojo/io/iframe Use dojo/request/iframe -- will be removed in version: 2.0."
"DEPRECIATED: dojo.moduleUrl() use require.toUrl -- will be removed in version: 2.0" (there are 4 of these)
What is causing these errors.  Is anyone else getting them.  I have a iPhone 4s running on iOS 6.0.1.
ConradSchaefer
FCD_MillerC
I am not having the same error, so far as I understand it, but experience what appears to be a related issue. I also get a script error that references "dojo". I don't know what "dojo" is so I can't be of help but our posts may be related.
http://forums.arcgis.com/threads/74221-Mozilla-Firefox-Script-Error
MikeMinami
Esri Notable Contributor
Chandra,
Those are just warning messages and can be ignored. How are you seeing them? your display doesn't look like the standard debug console for Safari...
Mike
ChandraMiller
The image I attached above is when I open my map on my iphone4s in the safari browers.  it doesnt look like this on the desktop computers.  You can scroll through the error messages but you can not close the error window on the phone.  Map url is http://maricopa.maps.arcgis.com/home/webmap/viewer.html?webmap=4dd4b8b8195846f3a2e54bf876800508.
ChandraMiller
Map is still looking like this on my iPhone (see image from 12-27).  Can anyone give me a clue to what is going on?
MikeMinami
is this actually a screenshot from your iphone?
I don't have the same OS as you, but I can see these messages only when the debug console is enabled in Safari. If you go to settings>Safari>Advanced you may be able to turn it off.
Mike
