Can Services be re-sourced in ArcGIS Online?
583
01-14-2013 07:48 AM
ShawnFrye
Can a map service or feature service be re-sourced if the server it is stored on changes names?  I will be moving several services from serveral maps to a new ArcGIS server that will have a completely differnent name/url.  Will I have to delete the services in the AGOL map, then add it back from the new location, and re-configure pop-ups?
Or can I just point the existing layer in the existing map to the new location and will it keep all the same pop-up information?
MikeMinami
Esri Notable Contributor
no, unfortunately you can't change the URL to the map service. You have to add it again.
Mike
