Map Missing In "Select A Map" Menu During Create A Dashboard
326
02-27-2026 04:27 PM
MikaSaddam
I would like to create a new Dashboard, I already upload series of data in the portal and already publish it but I still cannot select the map in "Select a Map" menu.
Please assist me to solve this error. Thanks
Katie_Clark
MVP Regular Contributor
From your description, it sounds like you've only published the layer, but haven't actually added it to a web map and saved it as a web map item in your organization. Is that the case?
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
