Log Search Widget Input
1425
6
01-08-2019 05:51 AM
GaryBarden
I'm looking to find out if there is a way to log the information that a named user is searching for via the search widget in a web mapping app?
RobertScheitlin__GISP
Gary,
   Not using the AGOL apps where you have to ability to change the code base.
GaryBarden
Robert,
What about in a custom app in portal?
Gary
Gary,
   If it is a custom app then you can add code and you can log the users searches.
GaryBarden
That's great....If you have a minute I have a couple follow up questions.
1.) If a named user were executing the search, would the code be able to include, named user in the log?
2.) Would you have an example of the code in question?
Thank you again Robert!
Gary,
  I don't have an example (never needed this myself). But to get the user you would need to add code using IdentityManager class and getCredential method
https://developers.arcgis.com/javascript/3/jsapi/identitymanager-amd.html#getcredential
To get the search term used you would need to get the Search dijits value property and log that
https://developers.arcgis.com/javascript/3/jsapi/search-amd.html#value
GaryBarden
Thank you Robert. I truly appreciate your input.
