Loading content online
2110
6
03-23-2017 07:49 PM
PaulHarvey2
When I load layer content via the My Content function on the online platform, I cannot seem to then be able find it to add it to maps and scenes. Is there a trick to getting the layer content to appear in the Add Layer section of the Map and Scene developer tools?
PaulHarvey2
Thanks everybody! It turns out that my local server was preventing some of the data from uploading properly, seems to be working now after some help from IT.
JayantaPoddar
Have you published the layer from ArcMap?
Publish hosted feature layers—ArcGIS Online Help | ArcGIS
Think Location
PaulHarvey2
Thanks Jayanta. Yes, I have published the layer from ArcMap. It uploads fine to the My Contents page but then can't be detected by Maps or Scene.
JayantaPoddar
Is "Within Map Area" box checked?
Uncheck Within map area if you don't want the results to be based on your current map extent.
Think Location
PanagiotisPapadopoulos
try the button more... in order to load more results
Also you can try add the layer using URL
from the hosted service copy the URL
and add this url on scene
PaulHarvey2
