Loading an API response in JSON to Map Viewer.
2280
12-17-2021 06:00 AM
Boyang_Wang
I am using an API for fleet management that responds in JSON with vehicle coordinates. This is how the JSON looks like:
https://api.silentpassenger.com/rest/v2/help/operations/GetDataPoints#response-json
I would like to draw these coordinates as points in ArcGIS Online Map Viewer. Do I need to use another API to convert JSON to ArcGIS compatible formats such as CSV, GeoRSS or KML?
Thanks!
Tags (3)
RussRoberts
Esri Notable Contributor
Yup you will need to convert it. I would recommend CSV or GeoJSON in the New Map Viewer.
Boyang_Wang
Is there an converter API ready to use for this purpose? I do not have web server so I think I cannot develop and deploy a converter by myself.
What about GeoEvent Server? Can that server be used for this purpose?
Deputy_Rico
With regards to the initial problem, I am also curious as to what program or application I should use to convert an API that is in JSON format into a GEOJSON format in order to connect and upload dynamic data into Map Viewer.
Boyang_Wang
My solution was creating a hosted feature service, using Python to convert JSON to CSV and cursor to write to feature service every 10 seconds. I am working in Enterprise environment, so I am not sure if this method will drain the credits in ArcGIS Online environment.
Deputy_Rico
Thank you! I will give this a try and see how it goes with the credits.
