Limited UTF-8 support
3719
04-25-2014 09:50 PM
YigalMuntner
1. When exporting to shapefile - Hebrew letters become gibberish.
2. Searching Hebrew tags return no results.
Yigal
by Anonymous User
Not applicable
Yigal,
Thank you for the feedback, we will log a bug for this. If possible, please post the data you are using so we can accurately address your issue.
Thank you,
Andrew
SimonLiu
I'd like to second this.
For example, the service below has Chinese characters in the attribute fields:
http://simon.techresearch.opendata.arcgis.com/datasets/9f0d2f8db081426eb396837a1bc77f68_1
Downloading as CSV is fine.
Downloading as a shapefile corrupts the text. However, from memory, the DBF format used by shapefiles to store attribute data has always had spotty support for non-ASCII characters, so there may not be much that can be done here.
Downloading as GeoJSON and viewing in a text editor seems to work OK, but I've noticed that when I click http://simon.techresearch.opendata.arcgis.com/datasets/9f0d2f8db081426eb396837a1bc77f68_1.geojson in my web browser, the Chinese characters are garbled if my browser's default encoding isn't set to UTF-8 (this will be the case for a lot of users in English-speaking countries). This can easily be fixed by getting the server to state the encoding in the HTTP response header (something like Content-Type: text/plain; charset=utf-8 rather than the ambiguous Content-Type: text/plain it sends at the moment)
