license issues
4690
03-18-2014 12:38 PM
douglascurl
Having trouble understanding the licensing for Portal for ArcGIS v10.2.1 - I installed Portal, have an ArcGIS for Server Advanced Enterprise license, yet the Portal extension does not show up in the list of extensions available when I do the Software Authorization. And, of course, when I go to the "Portal for ArcGIS website" (sent to after I install), I get a the "Software Authorization" screen that says "Portal for ArcGIS does not have a valid license".
I have contacted my ESRI license manager person for my organization, and I didn't get a clear answer on what is needed (he thought that Portal for ArcGIS and Geoportal were the same thing - and didn't understand much beyond that).
Can someone please explain how the licensing works to get Portal for ArcGIS running on my server? I thought it was like every other extension for ArcGIS Server, but apparently not?
JacobBoyle
this should help: http://resources.arcgis.com/en/help/main/10.2/#/Authorizing_Portal_for_ArcGIS/017s0000005n000000/
Basically, you need another ECP code from the ArcGIS Customer Support site.
WilliamCraft
Jacob is correct; your Portal for ArcGIS license will be a different code than your ArcGIS for Server license.  Portal was not meant to be authorized using the same Authorization wizard as ArcGIS for Server.  While it is technically an extension, I have found it to behave and be treated differently than other extensions for ArcGIS for Server.  It looks and feels like a separate application altogether, and it is authorized accordingly.
SteveBratt
Cool. But which license is needed? I don't see one called "Portal for ArcGIS" anywhere....
Thanks.
JacobBoyle
You have to contact your sales rep or customer service to get one created, as the linked page does not state, but really should! 😄
SteveBratt
Thanks Jacob! That's odd, but it is what it is!
