Layers adding themselves to other maps?
1357
08-25-2021 01:50 PM
Labels (2)
LynneSabourin
Hi everyone,
I am running into a weird problem. When I open a feature layer from "My Content" it keeps adding itself to either: a Web Map I was recently working on, or the last Web Map I looked at. Is there some way I am supposed to "close" a Web Map? I used to just navigate back to My Content and open something new in it's own Map Viewer with no problems. I am using the "Classic" Map Viewer.
Thank you!
David_Brooks
MVP Regular Contributor
Hi @LynneSabourin , yes, the default behaviour is to add to the current web map (with the current web map being the last one you had open). You need to click on the drop down arrow on the right, select Add to New Map:
David
..Maps with no limits..
David_Brooks
David
LynneSabourin
Thanks David!
