Layer geometry\drawing not rendering correctly in AGO
2707
5
08-09-2021 11:36 AM
Labels (2)
COSPNWGuy
Does anyone have any insight or experience with a feature layer in AGO not displaying\publishing correctly. It looks like the data becomes corrupt. I have tried repairing geometry in Pro. I have tried removing and adding back to the map. I have republished 5 times with the same results.
ArcGIS Pro
 Resulting Layer in AGO
Tags (4)
RussRoberts
Esri Notable Contributor
Can you share the SD generated?
COSPNWGuy
Hi @RussRoberts . Yes. The download is too large (175mb)  to post here. You can download from here.
RussRoberts
thanks! you can remove the link if you want I have the SD downloaded.
COSPNWGuy
Thanks. Doing that now.
RussRoberts
still looking into the issue and it looks like its an issue with the polygon being that size and shape is showing an issue with either multi scaling and/or quantization. Both im looking into.. but as a work around if you are using this as a reference layer  you can dice the feature up and turn off outline and it will mirror your expected result.
results in Map Viewer
