landsat.arcgis.com esriSpatialRelContains
1234
07-27-2016 12:45 AM
MarcJacquin
Using the Landsat8_Views (ImageServer)//query? with spatialRel=esriSpatialRelContains does not return any feature whereas using it with spatialRel=esriSpatialRelInitersects does.
Example :
with Intersects :
http://landsat.arcgis.com/arcgis/rest/services/Landsat8_Views/ImageServer//query?&f=json&where=Categ...
with Contains and the same Polygon small enough to contain many footprints :
No feature is returned.
Am I doing something wrong ?
Thanks for helping.
Marc
XanderBakker
Esri Esteemed Contributor
XanderBakker
Here an old document with a detailed explanation on how spatial relationships are evaluated:
Understanding spatial relations
MarcJacquin
Thank you Xander for pointing out this.
I did try the Within relationship but I came out to another issue which seems to be the main one.
Trying to count the features is OK :
Retrieving all the features is OK : http://landsat.arcgis.com/arcgis/rest/services/Landsat8_Views/ImageServer/query?f=json&where=Categor...
But when using  resultOffset=0 and resultRecordCount=20 for example, nothing is returned.
Documentation says that the  resultOffset and resultRecordCount parameters are available for 10.3.1 only but they actually do work when using the Intersects relationship.
