Labelling features?
6193
11
10-12-2011 12:59 AM
MartaPlos
Hi everyone
I am quite new in the arcgisonline world, so this might sound a noob question, but...
is it possible to label the features one ads on a map, instead of (or in addition to) using the popups?
Thank you
MikeMinami
Esri Notable Contributor
No there is no labeling capability at this time. It's a good idea though.
Mike
EricMcClure
Mike
A very good idea, will this be developed soon?
Eric
MikeMinami
No, there are currently no plans to implement labeling in the ArcGIS.com Map Viewer.
Mike
RupertEssinger
Esri Alum
You can manually add labels to an ArcGIS web map by drawing them on. You simply type in the text, so it isn't the same as feature labeling you are asking for, and the text doesn't scale with the map (so it remains the same size as you zoom in and out) but it might be a useful alternative. To add text labels to an ArcGIS web map, open your map in ArcGIS Explorer Online, choose Add Features, and you'll see a Text option under Map Notes.
StephanieCunningham
Thank you very much for this advice, it is perfect!!
BretRowlinson
Would just like to add that I would really like to see a simple labelling functionality added to arcgis online.
I have 3 maps now that would really benefit from it.
Cheers!
GregHunter
Hi Bret,
Have you seen this work around:
http://blogs.esri.com/esri/arcgis/2011/11/21/adding-labels-to-arcgis-online-web-maps-part-1/
It is limited with respect to the scale the text/polygons are useful for, but if you use scale visibility and multiple text layers it might be the best solution for now.
Greg
HarveySchroyen
Hi Rupert, i don't see where there is a Text option in the Add feature/Map Notes .. I only get points, lines and areas. Have they done away with Text additions?
JerryGarcia1
You can add labels.  When you publish the map service to your server make sure you have labels turned on. I use mapplex and all my labels and settings for the labels transfer over to AGOL.
