June 2026 Update - Issue with intersect calculations
410
6
06-30-2026 12:14 PM
WillyG
Hi. This was working perfectly pre June 2026 update.
I have an intersect calculation here, using FeatureSetbyName $map. It also uses a field which is hidden by conditional visibility to select the project area if project areas overlap.  The way it is designed if there are no project areas to choose, the field does not appear, and it instead gets the value from the single project area
Since the update, when I draw the feature it does not calculate but I move it slightly after drawing it, it does. This is currently not practical for the end user.
(see attached gif)
Kind regards, Willy
CraigGillgrass
@WillyG are you able to share map so we can look at it to investigate?  One way to do that is to invite my user "craig_sp" to the group this data is in.  Feel free to reach out to me on this through a DM.
WillyG
Hi Craig. No worries.. I'll add you to the relevant group(s) and DM you when I have done that
CraigGillgrass
@WillyG I believe this issue is running into the same issue we discussed in the DMs; removing the expression  to return the attachment-count should correct this.
WillyG
Thank you @CraigGillgrass  Yes. That resolved the issue we were having. Thank you very much
David_McRitchie
Hey Willy,
I had a support case come in that matches this behaviour. This got logged under BUG-000186071.
It is currently in the Product Plan so hopefully will be resolved soon. If you want to be updated on its status I would recommend raising a support case with your distributor and ask that they attach the defect to your subscription.
Esri UK -Technical Support Analyst
CraigGillgrass
BUG-000186071is a different issue @David_McRitchie
We're looking at it but do not have a timeline for a fix.
