Joins Supported?
2408
05-15-2013 08:03 PM
SimonJackson
I have a points layer that can have a field (a domain) edited via the Collector Application.
I have a polygon layer that is joined to this points layer, and symbolised by the same field.
Publishing from ArcGIS for Desktop to my ArcGIS Online for Organisational account = gives no errors around the join not being supported. However, in the web-map, the polygon layer does not show up in the map, although it appears in the ArcGIS Online webmap TOC.
Is this a known limitation?
MikeMinami
Esri Notable Contributor
Can you share the URL to your map? The layers (services) would also have to be shared.
Mike
