Join layer on AGOL not refreshing with new data
3122
10-23-2024 09:26 AM
esriuser12345
Hello,
I am following the inspection workflow as demonstrated in this video
https://www.youtube.com/watch?v=gqC-EEw3nxY
I have editing privilege on all my hosted feature layers. I create my join layer with my related work order table , and when I edit the related record in field maps, I can see the change reflected in the related record, however the join layer I made to display the work order data does not automatically refresh. Meaning, I have to make the join layer again if I want to display updated information.
Not sure what I'm missing to make this layer automatically update.
Tags (3)
How do you start to build a digital inspection workflow with ArcGIS? This video has you covered! You'll learn how to build related tables to store inspection records and then publish it to ArcGIS Online. Please check out some of our other videos about this workflow: Inspection Workflows Part 2: ...
AmandaRing
Hi @esriuser12345, are you using Map Viewer or Map Viewer Classic to create the join?
If you are using Map Viewer, the option to create a Hosted Feature Layer View Join, which is what will make the layer update dynamically as the source data updates, is not available in the Join Features tool in Map Viewer. Instead, there's a new way to create a hosted feature layer view from a join, located on the item details page of your target layer. You can check out the documentation here and this great blog post about the new method.
Hope that helps!
Amanda
Product Engineer - Web Analysis
AmandaRing
Hope that helps!
Amanda
SCVOSAGIS_Program
@AmandaRing I am having the same problem, and want to confirm that the steps in the video are superseded by the instructions you list? It's a great video series that I've borrowed from for multiple workflows!
AmandaRing
Yes, the steps in the video are outdated. You should instead follow the instructions listed above.
Amanda
