Join Features Analysis not respecting Hosted Feature Layer View filter? (Map Viewer Classic)
1525
03-23-2023 10:56 AM
Henry_PeleshBW
Hello,
I've noticed an issue when trying to run the Join Features Analysis tool in Map Viewer Classic. I need to use Classic because I need the output to be a Hosted Feature Layer VIEW, which is not available yet in the Map Viewer.
I have a Hosted Feature Layer View with some filters applied. When I use this View layer as the input for "Choose layer to join to the target", it is not respecting the filter applied at the View definition. Is there a limitation in the Analysis tool or am I perhaps doing something incorrect? @AmandaRing
Henry
Omar_A
by Esri Contributor
One way to troubleshoot this issue is to try using the same Hosted Feature Layer View without any filters applied and see if the Join Features Analysis tool works correctly. If it does, then the issue may be related to the filter. In this case, you can try modifying or removing the filter to see if it resolves the issue.
Create hosted feature layer views—ArcGIS Online Help | Documentation
