Issues with generating token/reading data after update on Wednesday
858
06-28-2025 08:42 PM
BigLouC
Getting this error from PowerAutomate with web hooks
Unable to process template language expressions in action 'Generate_Server_Token' inputs at line '0' and column '0': 'The template language expression 'decodeUriComponent(first(triggerBody())['changesUrl'])' cannot be evaluated because property 'changesUrl' doesn't exist, available properties are 'name, orgId, serviceName, lastUpdatedTime, events'.
This was working fine Tuesday, Wednesday no more.
I am using webhooks as per this example
https://www.esri.com/arcgis-blog/products/field-maps/field-mobility/use-webhooks-to-automate-workflo...
It now states that its outdated.
So did the update made the above unusable to move us to the new format?
BigLouC
Found the issue.
The update changed the structure if the json coming back after parsing edits
It used to be like this:
 "transportType""esriTransportTypeUrl",
        "responseType""esriDataChangesResponseTypeEdits",
        "edits": [
                "id"0,
                "features": {
                    "adds": [],
                    "updates": [],
                    "deleteIds": []
                "id"1,
                "features": {
                    "adds": [
Where the index for the data was in 1. Now they removed id:0 from the mix, so the index to get the data is no longer 1, but 0. Like below:
        "edits": [
                "id"1,
                "features": {
                    "adds": [
I updated the template line 'body('Parse_Edits')['edits'][1]['features']['adds']' to 0 instead of 1 and now it works.
I am not sure if this information was passed on what was updated, I did not see anything mentioned
BigLouC
Now sometimes it dies on the gettoken part, now it dies after parsing edits
InvalidTemplate. Unable to process template language expressions for action 'Apply_to_each' at line '0' and column '0': 'The template language expression 'body('Parse_Edits')['edits'][1]['features']['adds']' cannot be evaluated because array index '1' is outside bounds (0, 0) of array. Please see https://aka.ms/logicexpressions for usage details.'.
did something change in the template after wednesday?
@JoshuaClifford1
BigLouC
Found the issue.
        "edits": [
                "id"0,
                "features": {
                    "adds": [],
                    "updates": [],
                    "deleteIds": []
                "id"1,
                "features": {
                    "adds": [
        "edits": [
                "id"1,
                "features": {
                    "adds": [
