Issues adding KML file to Map Viewer
11942
19
03-16-2022 10:14 AM
JD1016
I've seen one other posting that was made some time ago regarding this issue but there was no resolution.
I am attempting to add a KML file to a Map Viewer web map and received the following somewhat "cryptic" message "Error...there was an error".  Unfortunately, not particularly helpful on the elaboration front.
However, I was able to successfully load the KML file using Map Viewer Classic but I need Map Viewer's Group Layers functionality.  Of course, I could back track, load everything in Classic, open it again using Map Viewer, and then re-do my groups but I would prefer not to employ that as a consistent work around.
Has anyone experienced this issue and, if so, is there a solution for this problem?
Thank you.
Jeff
RussRoberts
Esri Notable Contributor
Yup so in the URL is the item id for the KML that you would use in this URL would look like this.
https://jsapi.maps.arcgis.com/sharing/rest/content/items/3e1d02d34bfc440f9a83587ac2a529df/data?f=jso...
JD1016
Worked perfectly!!!  I've never used that tactic before, aside from using the URL of a hosted and publicly shared layer.
Thank you for hanging with me, Russell.
Jeff
MaryAnne_VanZuyle
This works if the kml is hosted on AGO. I have a kml from a consultant who uses non-ESRI software. I can add the kml to a Map Viewer Classic map, but it not visible when I switch to the new Map Viewer. Is this a known issue?
RussRoberts
Can you share the KML?
MaryAnne_VanZuyle
RussRoberts
no worries! glad to help out and its on the roadmap to support KML the same way as classic.
RussRoberts
Just as a heads up this issue has been fixed and the modified URL is not required.
JD1016
Thank you for the follow-up, Russell.  Much appreciated!
JoeBryant1
Hi Russ - at what version of ArcGIS Enterprise is this issue fixed? We are still on 10.9 as we are still supporting ArcMap alongside ArcGIS Pro.
owlly
you can try the embedMap webapp , it use KML data too: https://www.owlapps.net/modules/owlapps_apps/embedmap
