Issue with special characters in Azure Active Directory ldp guest usernames integrating with ArcGIS Online
4213
06-30-2021 11:23 AM
FrankMartin1
We've switched to using Azure AD authentication for ArcGIS Online.   For guest users (not in organization), Azure AD creates a username (User principal name) that includes special characters (#'s), ex. somebody.somewhere.org#EXT#@acme365.onmicrosoft.com.  This username cannot be use for the SAML ID when adding a member to ArcGIS Online.  See image below.
Has anyone seen this problem before, and is there a solution?
Frank
Tags (3)
DerekLaw
Esri Esteemed Contributor
Hi @FrankMartin1,
A couple of possible workarounds you could try:
"Try to use automatic user registration. Since you are creating new accounts for external users, you could turn on automatic registration, test automatic registration & login for each new account and then turn off auto registration.
Another way to workaround this, if you don’t want to enable auto user registration, would be to add members from a file:
Email,First Name,Last Name,SAML ID,User Type,Role
[email protected],Firstname,Lastname,username@org#EXT#@dept.company.com,Viewer,Viewer
This also will preserve the ‘#’ characters in the idpusername, while the username is normalized."
Hope this helps,
DerekLaw
Hi @FrankMartin1,
Hope this helps,
RenaudJOGUET92
Hello @DerekLaw ,
Does this solution work on Portal 10.9 (linux installation) ? We are not able to correct the problem on Portal 10.9 (with auto user registration disable and file)
Renaud
DerekLaw
Hi @RenaudJOGUET92,
Apologies for the late reply. I don't have much experience working with ArcGIS Enterprise on Linux OS so I can't say if the solution will work. Please contact Esri Tech Support - they are the best folks to help you resolve your issue. Sorry.
