Is there a feature count limit for publishing to ArcGIS Online?
1368
05-29-2018 07:42 AM
WhiteWaterMidstream
I am trying to publish some layers to ArcGIS online web map which have a couple thousand records. One point and one line feature class. I am publishing from ArcGIS Pro and it completes without error. However when I check the web map in ArcGIS online there is no data in my published layers.
Is this a known limitation, and is there a work around for this problem?
Thank you,
Lee Davis
Senior GIS Specialist
WhiteWater Midstream
by Anonymous User
Not applicable
There is no limit. You should be able to publish a couple thousand records without issue. Did you run the analyze before you published? Were there any errors?
Try running the Check Geometry tool and see if there are any errors.
by Anonymous User
Not applicable
WhiteWaterMidstream
I ran both, no issues. It is a GIS mystery.
by Anonymous User
Not applicable
Please open a Support case. If you need assistance getting a case created please let me know.
AndrewBarker3
We're having problems publishing non multi-patch features to Portal/Enterprise and during Analysis they fail due to being more than 2000 features.
I'd love some explanation as to why this error is appearing please.
