Is it possible to hide a popup based on attribute?
1579
05-03-2024 04:46 AM
AngelaSchirck
Hi all,
I am using WebMap Viewer and would like to had a popup for certain attributes.  I have Parcel Control Numbers (PCNs) that are 17-digits and 10-digits.  I want to hide the popup info for the 10-digit PCNs since this leads to bad links.  Does any one know a way to do this?  I'm not afraid of a little programming (python, arcade) if that is what it takes.
Thanks!
CodyPatterson
MVP Regular Contributor
Hey @AngelaSchirck
You can enter an expression and show that field as having data when meeting a condition, I haven't found a way to conditionally enable pop-ups if that's what you're mentioning.
You can use this here to find the count, and this would match your specific use-case:
var <your var> = $feature.<feature name>;
if (Count(<your var>) <= 10) {
    return <your var>;
} else {
    return "";
You can hit "Select fields" and then "Add expression" to do this. I would disable the viewing of the original ID and give this one a similar name for use!
Hope this helps!
Cody
AngelaSchirck
Thanks Cody,
I'll give it a try.  I tried just adding a filter to the layer, but there's no option to write code in the filter, you have to just pick from a set of options which don't include "string length." 🙂
CodyPatterson
Hey @AngelaSchirck
I've attached a GIF that explains what I did , hopefully that helps! If it doesn't end up showing what you need, could you attach a screenshot of what you're attempting to do?
Hope that helps!
Cody
