Is is possible to add services secured by a self-signed certificate?
1048
01-28-2013 07:18 AM
HugoMaurício
I'm trying to add a layer published on an ArcGIS Server to a map.
I'm using a self-signed certificate on this server and after I type the user and password I get this error (check image).
[ATTACH=CONFIG]21132[/ATTACH]
If yes, do you have any clue of what could be wrong?
I can successfully add the same data to an iOS app, provinding the same credentials and adding the server to the trusted servers list.
Hugo Maurício
MikeMinami
Esri Notable Contributor
We don't support self signed certificates out-of-the-box.
The identity manager uses the proxy to talk to the server's token service. An exception for self-signed cert has to be made in the proxy code. We can give you the code for adding this exception to JSP proxy. Do you have a JSP or .NET proxy?
It would be okay to use the exception for development/testing purposes within the firewall. It's generally not recommended to use self-signed certs for apps deployed on the public web.
Mike
