Intersecting Selected Feature with one Buffer Zone in Pop-Up
1092
03-14-2024 12:35 PM
Labels (3)
ClintHewlett
I am trying to create an expression that will show whether or not a selected parcel polygon intersects with a buffer polygon in my experience builder. My understanding is that when I call $feature in an expression it is referring to the currently selected feature. My assumption then is that when using Intersect() i can compare a selected feature with the entirety of my buffer polygon using the following code:
if(Boolean(Intersects($feature, FeatureSetByName($map, "Dispensary Buffer")))){
  return 'This parcel is not eligable for development.'
} else {
  return 'This parcel may be eligable for development. Please contact City of Columbus Building and Zoning Services'
Am I misunderstanding the scope of $feature?
ClintHewlett
It seems my issue was that FeatureSetByName() returns a feature set and I needed to access the feature within that feature set. Using First(FeatureSetByName($map, "Dispensary Buffer")) gives Intersects two feature geometries and returns a boolean.
ClintHewlett
