International date format
597
01-06-2026 02:37 PM
DavidChanIWC
Is there a way to force AGOL to display dates in data tables in any format besides the American default? My organisation is Australian. Our organisation settings are set up correctly:
Region: Australia,
Language: English - English,
Number and date format: Australia - Australia‎.
Member settings are inherited from the organisation so it's not an issue of personal setting overriding to American datetime.
However, all of our tables where there is a default date column still displays using mm/dd/yyyy format. This is fine in some cases where it is clearly evident i.e. 1/31/2026 but the majority of cases this is incredibly misleading for pretty much everyone.
Popups I can configure to display in the default Australian format, but this shouldn't need to be the case. The data should default to respect our settings.
VenkataKondepati
Honored Contributor
No, there’s currently no way to force ArcGIS Online data tables to respect regional date formats. AGOL tables render date fields in a fixed US-centric mm/dd/yyyy format, regardless of org or user locale settings. Org settings do apply to pop-ups and labels, but tables are hard-coded on the client side. It’s a known limitation, not a misconfiguration on your end. Until Esri changes this, the only safe workarounds are popup formatting, calculated text fields, or views with formatted date strings.
Regards,
Venkat
Book a meeting with me:Get on a Call
Follow me on: LinkedIn
If this response helps or is the solution to your post, please consider marking it as a solution
EmilyGeo
Hi @DavidChanIWC
Yes, you can display the date in the table using the format you describe. First, make sure the settings (in My Settings) are set to Australia - Australia‎. Then in Map Viewer you can format for the date field in the Fields pane and that will persist across both pop-ups and tables:
gis_KIWI4
MVP Regular Contributor
@DavidChanIWC  - There are organization settings and there are user specific settings.
Try changing them in the user profile settings.
It took us a while to realize this.
Hope this helps.
RTPL_AU
@DavidChanIWC
Check your computer's locale settings.
Sometimes the US manages to creep into unwanted spots after a Windows update.
I once had these settings changed unknowingly and it confused me a lot as nothing in Pro / AGOL was set incorrectly.
