Interactive Legend Application Layers startup
1380
03-11-2021 01:43 PM
TKSHEP
Is there a way to turn the layers off on startup of the interactive legend map and only have 1 layer show unless you turn the other on?
Thank you,
BernSzukalski
Esri Frequent Contributor
In the full setup mode you can add a layer list which lets you toggle layer visibility. Save your map with only the layer you want visible, and if you want to show the other layers (and add them to the interactive legend) use the layer list to turn on visibility.
TKSHEP
Not exactly what I was thinking but this will work.
Thank you!
