Initial/Saved Extent not being honored
4557
12-17-2012 11:08 AM
DublinOhio
Any webmap I open in ArcGIS Online seems to have a different extent (zoomed to full extent) than the last time we saved it. For example http://bit.ly/UgA6TQ - should be zoomed to where the data is. I have even opened, zoomed, saved and next time I open it is back to full extent.
I don't know if this has anything to do with it but we do not use any Esri basemap - we use our own aerial photo as the "base map" in the web map then add our operational layers. All had been fine until this last update.
Brandon
MikeMinami
Esri Notable Contributor
This issue will be addressed this week. No changes to your web map should be required. It should just start working.
Mike
JorisBak
Brandon
Yes, we also noticed this. We logged an incident with support today. It seems like an issue in ArcGIS.com map viewer, the app templates and also Flex Viewers load correctly with the saved extent.
MikeMinami
There appears to be a problem saving the extent when the web map has a custom basemap. As a workaround, I did find that if I use the standard Imagery basemap,the extent saved correctly.
A few questions:
Why are you adding the Historic Building Info and Building Information layers separately in your web map? They appear to be part of the Historic District layer already.
I also noticed that the spatial reference of this service
http://maps2.dublin.oh.us/ArcGIS/rest/services/DowntowneApp/MapServer
doesn't match your basemap. For optimum performance, they would match.
Mike
MikeMinami
Mike
JamieRobertson33
Hi Mike,
At Argyll and Bute Council, we use ESRI maps for customers submitting geographic based issues such as Fly Tipping.
Our maps are no longer initially focusing on the street a customer has searched for.  The issues appears to be that initialExtent is not being set.  Is this to do with the issue/fix you are mentioning here?
Jamie Robertson
