In Arcade is there FeatureSetByName but for tables?
1628
07-29-2019 02:44 PM
DougBrowning
MVP Esteemed Contributor
There does not seem to be an Arcade group for some reason so trying here.
I have been using FeatureSetByName for Feature layers and it works great.  But it does not seem to work for tables.  I just nothing back from it.
There is not a TableSetByName or anything like that.
So how can I query a table?  Tables are left out in the cold in Esri products a lot so I am afraid of the answer.
var sql = "PrimaryKey = '" + $feature.PrimaryKey + "'";
var tbl = Filter(FeatureSetByName($map,"Photos"), sql);
var link = ''
for (var f in tbl) {
    link = f.PhotoLink
return link
tbl comes back blank
thanks
DougBrowning
I should also note we are only doing this because the relationship/PhotoLink works randomly sometimes and not others.  Sometimes it auto changes to a link and then we republish and it is gone.  Cannot find the pattern yet.
thanks
XanderBakker
Esri Esteemed Contributor
Hi Doug Browning ,
The FeatureSetByName function works for both feature layer and tables. If you have a look at the post below, you will see that the access to "related" is established by using the FeatureSetByName using the exact name used in the $map  (in this example there isn't even a relationshipclass between the two):
https://community.esri.com/docs/DOC-12773-using-featuresetby-functions-in-arcade-to-drill-down-to-ot...
Just scroll down to the second expression where a table "hist_mantenimiento" is accessed.
If your primary key is a GlobalID, your SQL expression will probably be different.
DougBrowning
Thanks.  It turned out to be that the map was zoomed into a point that just happened to have no PhotoLink.  So it was returning a blank set - but not for the reason I thought.  I have had issues with FeatureSet vs RecordSet before where RecordSet was not working so I just thought it was the same issue.  (see this post https://community.esri.com/thread/213089-using-a-agol-hfs-in-python-directly )
Seems to work now.
Thanks
