I've been trying to calculate the valley floor width to valley height ratio of a lot of basins, I'm fairly new at using ArcGIS so I tried using a already made tool I was recommended that you can find here: github-ValleyMorphTool but it does not work, it finds errors in every basin I have and skips them, even in the test package that comes with the tool it doesn't seem to work, I'm using ArcGis 10.7 and I noticed the tool was tested on 10.1, could that be the reason it's not working? If so could someone tell me some other way to calculate it?
I've been having a similar issue. I tried using ValleyMorph on 10.8 and the toolbox will not install so I think it is a version issue. Have you been able to find an alternative method?
Look at this: https://github.com/crpp0104/ExtractValleyFloorTool
also: https://en.x-mol.com/paper/article/1307990524341489664
best
allosa01@gmail.com
