I'm trying to print a full size map from an ArcGIS Online map.
3220
11-20-2015 02:54 PM
MatthewJoy
I have a map that I've made on ArcGIS Online. When I hit the 'print' function, map is very small. I would ideally like to have the printed map the size of a regular printer paper. Are there any other printing options? This seems pretty limited. I do not have access to Desktop if that's important.
MichaelJach
I tried printing out one of my maps from ArcGIS Online and got a small preview window. Then I tried converting that map document to a Web Mapping Application and printing from there. It seems to work better, but you'll have to play with it to print it out right. Hope this helps.
DellaRobertson
Occasional Contributor II
Matthew,
What I have done is make a print screen, then print that out.
I have also used Paint to edit the print screen.
I may have made a pdf of the print screen.  It's been 6 months since I tried to figure out how to make a large map.
Have you posted to Geonet Help?
