I am trying to use a text element with two attribute expressions. I want the URL field in the pop-up to hyperlink to the URL, but have it display "Click here for more info." I can get it to hyperlink to where I want it to go, but it is showing the full URL, not the alias I am looking for. Currently, this is what it shows.
1st expression {expression/expr0}
var annexYear = $feature.ANNEX_YEAR;
var annexDate = $feature.ANNEX_DATE;
var acres = $feature.ACRES;
var name = $feature.ANNEX_NAME;
var annexationDate = Text($feature.AnnexationDate, "MMMM D, YYYY");
return "Annex Year: " + annexYear + "\n" +
"Annex Date: " + annexDate + "\n" +
"Acres: " + acres + "\n" +
"Name: " + name + "\n" +
"Annexation Date: " + annexationDate + "\n";2nd expression {expression/expr1}
var link = 'https://server.domain.com/maps/' + UrlEncode($feature.URL);
return linkText element:
{expression/expr0} URL: {expression/expr1}
Solved! Go to Solution.
I think I answered my own question. You can edit the HTML in the text element, but the OK button gets greyed out. You have to exit the HTML mode then click ok.
