Hybrid Reference Layer (for Export) - how to export without basemap
3440
11-21-2021 09:43 AM
MarkC1
 I want to export the Hydrid Reference Layer for offline use. I can get halfway there but I'm not getting the exact result I want. I want just the road, rail layers, not any underlying basemap.
Using the vector tile layer Hybrid Reference layer (for export):
https://www.arcgis.com/home/item.html?id=e7817b59ec4b40e4a1e55241b8695534
I can export the tiles using:
https://basemaps.arcgis.com/arcgis/rest/services/World_Basemap_Export_v2/VectorTileServer/exportTile...
, however the resulting VTPK has the hydrid reference layer on top of the streets layer
Like this:
 , when I just want this:
ABishop
Hello Mark,
My guess is that you are trying to create an export of tiled images and not just vector images.  Is there another data source online that you could use with similar data as the the hybrid layer that contains only vector layers?  Or are there options to turn all the layers off except the vectors before processing?
Amanda Bishop, GISP
MarkC1
Yes, that's essentially what's I'm doing. I ended up just using OSM shapefiles, not as good but it will have to do for now.
asiegel_HEC
I'm running into this same issue. Can't figure out how to just get the reference layer and not the entire basemap...
