HTML pop-up define AGOL with Video
14706
18
07-24-2015 08:20 AM
MikeSchudel1
Hello everybody
I wanted today PopUp in HTML mode in the WebMap this goes without problems.
But as soon as I want to make a web app and go back sees the HTML fileis different.
The same the reload from WebMap only, ist the HTML code the (recopy).
Is there somewhere guidelines on what should be in this HTML code in it?
Do you run a video a better solution to the popup from AGOL?
The HTML code (Original):
<html>
    <head>
        <title>{TITEL}</title>
    </head>
    <body>
        <video controls="true" height="100%" poster="{IMAGE_URL}" width="100%"  >
        <source src="{IMAGE_LINK_URL}" type="video/mp4">
        </video>
    </body>
</html>
The HTML code (recopy):
<video controls="true" height="100%" width="100%">
<source src="{IMAGE_LINK_URL}" type="video/mp4"></source>
</video>
Tags (5)
MikeSchudel1
Hi Kelly
thanks for teh support, im posting the answer with esri support in switzerland.
I think, i hope....
Greats Mike
BrianFee
Good morning, Kelly
I am using the method you posted to embed a video into my popup.  I had success using your video, but no success with mine.
I have some questions.
Is there a limit to file size? I am using a .mov file, but it is 77mb.
Are there specific file types allowed? I tried using a .mp4 and a .mpg.
Matt
KellyHutchins
Esri Notable Contributor
I'm not aware of any limitations. Perhaps you can post an example?
BrianFee
MikeSchudel1
Hi Brian
the first is the link is not for the MP4 video.
The other two can I download and Watch.
Unfortunately, I can with your card the PopUp not configure it, so I can not see what's wrong here as well.
Can you tell me this still see or share?
Best you take my suggestion in the text above.
Greeting
Mike
ShitalDhakal__GISP
Hi Kelly,
Thank you for the HTMLs. They worked for me for the first time, however, on refreshing the webmap, I cannot see the video in the pop-up again. Also, when I pass the web map in a Web AppBuilder App, the video in the pop-up doesn't work, it's just a plain rectangle with a play button, no videos.
Do you happen to know what is going on?
Shital
MikeSchudel1
This is a Software Bug by ESRI Inc.
The Bug-Number is :
[BUG-000090407 : Poster attribute gets stripped from the Custom Attribute Display Pop-up configuration in ArcGIS Online Map Viewer]
http://support.esri.com/
Waiting for the Improvement...
Thanks ESRI for debug.
Mike
KellyHutchins
Looks like this was fixed in last night's ArcGIS Online update.
MikeSchudel1
Hi Kelly
Keynote Apple an my problem by ESRI Inc. fixed in the same time 🙂
Mike
