How to return a group ID from an ArcGIS.com group
6622
07-20-2011 07:59 AM
NelsonDe_Miranda
When using arcgis.com you can search for groups ie.
http://www.arcgis.com/home/group.html?owner=tcostain&title=Central%20Eastern%20ESRI%20Commercial%20U...
However, to query this group I would like to use its "group id"
How can I retrieve this?
RaulJimenez1
In case someone else have this same issue again I just built a simple interface (source code available on Github) to get this job done:
Get group ID - Group ID Finder for ArcGIS
Cheers,
Raul
NelsonDe_Miranda
Mystery solved.
Use a browser debugger ie. Firebug
RamonLeal_Pessoa
It is possible accessing the site ArcGIS Online Group ID at http://www.esri.com/public-maps-gallery/group-id-tool/index.html.
Have a good work!
RaulJimenez1
Cheers,
Raul
KellyGerrow
Esri Alum
You can also use the following links to find out more about finding group IDs:
Documentation:
Find group ID | ArcGIS API for JavaScript
Sample:
Group ID Finder
