Hi, I have a Web Map App. Recently I see a "Oauh 2.0" in the Web Map App Overview page.
There is description saying "A registered OAuth 2.0 application. May use premium or subscriber content" when I click this "Oauh 2.0) icon.
How do I know which of my content is "O Auth 2.0" application, and how do I remove this ?
Thanks for any help!
Da-Wei
Sharing this documentation that might help clarify your questions with information about OAuth 2.0, the industry-standard protocol for authorization.
https://developers.arcgis.com/documentation/mapping-apis-and-services/security/oauth-2.0/
As I (somewhat dimly) recall, back around the June update, perhaps earlier, there was a behind the scenes change that exposed the OAuth badge on some applications. To remove that, you can go into the app settings and unregister it.
Hi, Thank you so much.
Do you know where can I find those options ? I cannot see this in my web app setting page as the following.
Thanks.
Da-Wei
If the app is registered, you will find that in Settings > App registration:
Was solution ever found for this? I recently ran into the same issue with an application I use frequently. Out of nowhere, somehow it now has the OAuth 2.0 lock, and I don't see those settings shown above to remove it.
I just created another webapp builder to replace the one has problem, and it solved.
But I also created an experience builder app to replace the old one.
Da-Wei
