How to remove an unavailable layer?
3281
05-26-2016 04:18 AM
PavelVeselský1
I have a map with unavailable layer. Now I don't want to debug it, but to remove it from my map and get rid of the "layer X cannot be added to map" messages. However, it doesn't appear in my content tab, so usual way to remove layer is unavailable here. So how can I remove the layer?
Tags (1)
AdrianWelsh
MVP Honored Contributor
Hi Pavel,
Take a look at AGOL Assistant. In there you can modify your maps differently with a little more control:
ArcGIS Online Assistant
FC_Basson
If you save the map to a new map, is the layer still requested?
AdrianWelsh
Hi Pavel,
FC_Basson
Oh wow I didn't know about AGOL Ass Thanks for sharing.  Definitely going to use it!
PavelVeselský1
Not full programmatic access, but close to! Thanks, it worked in my case!
