How to overwrite web layer used in hosted feature layer view with joins?
639
05-21-2025 08:07 AM
TL2
Error: ArcGIS pro ERROR Code 400, Unable to Delete Item. This Service Item Has a Related S
Is there a workaround to overwriting a web layer that is used in a View Layer?
ESRIs solution is to delete the view but this is obviously problematic in PRD.  Are there any solutions that work?
Tags (3)
JonM32
@TL2 My understanding is you'd have to delete the view, overwrite the service, and then recreate the view with the new service.
You could schedule a day for down time, overwrite it and then make a new view.
Jon M
Cheers,
Jon
If this response helps or is the solution to your post, please consider marking it as a solution
