How to load a directory of rasters into a geodatabase using Python?
4464
12
11-15-2016 04:50 PM
DaveBranson
I am trying to use Python in ArcGIS 10.4 to load a directory of JP2 images into a raster catalog.
I can load individual files but can figure out how to load all of the file at the same time.
this will load individual files ....
>>> import arcpy
>>> from arcpy import env
>>> env.workspace = "d:/data"
>>> arcpy.RasterToGeodatabase_conversion("Image1.jp2;Image2.jp2","d:/data/Database.gdb/Orthos")
I tried creating a list of the rasters with arcpy.ListRasters and replace the Input_Rasters with the list name and this works if there is only one item in the list.
Txs.
ModyBuchbinder
I think all this should be in the Python area...
The first question is why do you want to put your images "in" the FGDB. It just make them bigger.
I think you want to build a Mosaic Dataset inside the FGDB that point to the rasters on disk and look like one raster in ArcMap.
Check this: What is a mosaic dataset?—Help | ArcGIS for Desktop
Have fun
Mody
RebeccaStrauch__GISP
I agree, that is a better option.
NeilAyres
Definitely. The current esri "Pattern" is to leave rasters in whatever format you got them in. Then create a mosaic dataset referencing the original images.
