How to create comparative heatmaps
4250
06-16-2021 01:45 PM
Labels (2)
elterrell4
I've created 3 heat maps using kernel density and want the classification/range/color scheme to be consistent across all 3.  One of them has much higher numbers.
Map 1: (9 classes) goes 1 - 1607
Map 2: (9 classes) goes 1 - 282
Map 3: (9 classes) goes 1 - 337
I've tried manually entering them.  When I manually enter for map 1, I use break values/increments of 200.  When I try and do that with map 2 and 3, it won't allow me to enter 200 as the second break and in fact changes a break farther down to 200.
If I can't get the color scheme and the break values consistent, the heatmaps won't be any good for comparing year to year.
Any suggestions?
DavidPike
MVP Notable Contributor
Generally you'd use the class break/intervals of the feature/raster with the largest range, which is correct.
However your intervals of 200 will only give you 2 classes in maps 2 and 3.  If that's what you're happy with then the only issue is that I don't think you can't set a class break beyond the maximum value of the raster.  A simple solution will be to change the label in the legend from say 201 - 236 -> 201 - 400 (although this is against my opinion that the legend class should not be deceptive in it's maximum value).
For ease, what I generally have done in the same situation is to save Map 1's symbology into a layer file, then use that layer file to symbolise the other rasters. Properties->Symbology->Import from layer file.
DavidPike
elterrell4
Worked perfect, thank you David.
