How to convert a point layer to a polygon layer?
2542
10-22-2020 05:18 PM
dpatton
I am trying to alter a rather large dataset about solar radiation across the US.
https://arcg.is/0fvmu5
This map was downloaded from the NREL as a zip file. The table has an ID, Gridcode, Long, Lat, etc. The data is gridded into 10km by 10km squares.
GIS recognizes this layer as a Polygon layer, and gives me quite a few styling options to represent it.
I wanted to calculate an optimal tilt for solar panels based on Latitude and add it to my pop-ups. I exported the map's table as a CSV and did this calculation in Excel. The new table is identical to the one I exported except that it has a new column that is the optimal tilt.
I imported this new table back into ArcGIS online, however, it uploaded as a point layer instead of a polygon layer. When mapping any data, it represents my data as points instead of polygons.
Singular points still represent a square area of 10km by 10km. The data is actually identical to my previous map (save for the new addition). I only have two styling options, neither of which represent my data efficiently.
As I stated previously, GIS lists this new feature layer as a point layer instead of a polygon layer. I am confused as to why this is the case. Is there a way that I can change this to a polygon layer so that I have more options in visually representing this data?
Tldr: GIS online views my feature layer as a point layer. I want GIS to view my point layer as a Polygon layer.
DanPatterson
MVP Esteemed Contributor
You could have joined the point layer to the polygon layer to get your desired attributes back to the original dataset
... sort of retired...
dpatton
Yes, I did consider that, but the dataset is too large to be used with the Join Features tool. After about 6 hours of it processing that analysis, I gave up on it.
DanPatterson
That leaves you with converting it back to a raster because converting a point to a polygon is going to be a more onerous computational task
PaulSweeney3
If you have pro you can do a join and just calculate the field s across its quicker then join field's.  Can the calculation  be done directly into the table on arcgis online ?
DanPatterson
Sorry, I don't do arcgis online much and I tend to use arcpy.ExtendTable to do joins.
