how to configure forminfo in a webmap ? in Enterprise too
1030
12-01-2022 01:24 PM
LaurePillet2
i need to configure the forminfo "part"  of my webmap as described in formInfo | Web Map Specification | ArcGIS Developers
how to proceed best? which tool can i use ? i am searching for an user interface like popup configuration in map viewer but i can not  find something similar for forminfo.
i need a tool available in Enterprise too.
thanks in advance for your help.
regards
RussRoberts
Esri Notable Contributor
Map Viewer in ArcGIS Online supports authoring forms
https://www.esri.com/arcgis-blog/products/arcgis-online/mapping/smart-forms-arent-just-for-field-map...
Enterprise supports this as well but wont cover exactly the same features you see in the blog above.
https://enterprise.arcgis.com/en/portal/latest/use/create-form-mv.htm
LaurePillet2
thank a lot for your reply. very helpful and informative.
my problem is that i am working in an enterprise 10.9.1 environment and do not have this nice tool described in https://enterprise.arcgis.com/en/portal/latest/use/create-form-mv.htm
seems to me that the only way to have forminfo configure is to implement a script generating forminfo from popupinfo.
does somebody implement such a script ?
is there any other way ?
i do really to find a solution.
thanks one more  time
