How To Change Application CSS with OnLoad?
1378
07-21-2012 10:36 PM
JohnWeiss
Hi, i'd like to change the CSS of the default application after it loads. The element i'd like to change is id popup_1, the layers palette. (it's ID changes on subsequent clicks, but I'm ok with that for now).
My simple objective is to keep the built-in layers palette open at all times. I posted this question on this other thread, but started this separate thread to specifically explore "OnLoad" methods.
http://forums.arcgis.com/threads/49867-How-To-Keep-Layers-Button-Open
i attempted to do this using window.OnLoad, but it did not work.
What's the appropriate way to dynamically load css after the application loads?
Do i need to use a javascript function to register the OnLoad function?
Do i need to "chain" my function on arcgis existing OnLoad functions? Here are two methods i found to accomplish that, but want to hear from the experts before i started blinding trying stuff.
http://onwebdevelopment.blogspot.com/2008/07/chaining-functions-in-javascript.html
http://www.brothercake.com/site/resources/scripts/onload/
Of course, the simplest possible method is preferred.
help is much appreciated!
JohnWeiss
can someone please point me in the right direction on this?
thanks!
MikeMinami
Esri Notable Contributor
I'd suggest posting programming questions here:
http://forums.arcgis.com/forums/15-ArcGIS-API-for-JavaScript
Developers monitor that forum, but rarely visit this one...
Mike
