Is it possible to change the edit capabilities (add, update, delete, etc) of an ArcGIS Online feature layer using the Rest API? If so, what would a sample url/post look like? Thanks!!!
you can use arcrest (package python)
here you can see sample change capabilities: ArcREST/_update_feature_service_prop.py at master · Esri/ArcREST · GitHub
ArcRest: Esri/ArcREST · GitHub
