I have a simple table with the following tables in a hosted feature:
ID,Date, Location,Type
I need to create an arcade expression which I can use to as a label to display the number of features which were created up to the date in the DATE column. In this way I can return the cumulative number of records which were created up to and including that date.
My example uses the number of covid-19 case recorded. I record the date the record was created and the type of case.
I would like to display in a chart the cumulative number of cases up to and including the last record.
Thanks for any help
