How to build REST attachment URL using Arcade
1207
01-07-2025 08:30 AM
TD1
Been playing around with Arcade to build a REST URL which points to the photo attachments on the record.
I have 1,400 records with photo attachments (most have more than one attachment) and this is what I have so far but it's pulling the attachment ID and how do I handle separate URL links for each attachment on that record if there are multiple?
var Part1 =       "https://services.arcgis.com/Enter ID/arcgis/rest/services/ Enter Feature service/FeatureServer/0/"
      var ObjectID = $feature.OBJECTID
      var Part2 = "/attachments/"
      var AttachID = $feature.AttachID
      When($feature.CountAttachments > 0, Part1 + ObjectID + Part2 + AttachID, null)
FlorianArtelt
Is this case, you should have is array of attachment IDs in the variable "AttachID".
You have to use a for-loop and go through each ID.
Something like this:
var attachid = [1, 2]
    var textstring = []
if (count(attachid)>0){
  for(var id in attachid){
    var textstringpart = "BaseURL/" + Text(attachid[id])
    push(textstring, textstringpart)
return Concatenate(textstring, ", ")
If you want to have a clickable link, you need to have a couple of fields for each link.
