How to add a developped application inside the platforme arcgis online
1728
6
12-12-2013 12:01 AM
Abdoulaye_Djibril_MademouDIALL
Hello every one
first ,I want to apologize for my  grammar errors because I'm French .
In fact , I wonder if it's possible to add and use a  external application that I have  developed .
I would like to add my application  inside the arcgis online platform ?
thank you  for any clarification.
RichardWatson
It would helpful if you could give a specific example of what you are trying to do.
ArcGIS Online does not allow you to upload code which executes in the context of ArcGIS Online.
Here is a useful link (look at the template discussion):
http://resources.arcgis.com/en/help/arcgisonline/index.html#/Create_maps_and_apps/010q000000z2000000...
HeathBrackett1
Is this an application that is already web-enabled and deployed with its own URL?  If so, you can simply use ArcGIS Online to point to that application.  Do that by adding an item to My Content.  Choose that it's On the Web, and an application and register it.  Then you can make it public.  The application is not hosted on ArcGIS Online, but can be accessed through ArcGIS Online.
Heath
Hello ,
Thanks for yours differents responses,
In fact i need to host the Application on Arcgis Onlnine  without using just a link as said  << Brackeh >>
i want know if it 's possible ? if yes How ???
Thanks Aigain for your help
MikeMinami
Esri Notable Contributor
ArcGIS Online doesn't support custom hosting web applications.
Mike
thanks aigain for the reply ,
i want to know if i could not host the application in arcgis Online how can i controle the use of credits ?
thanks
To be more explicit ,
We have implemented a platform arcgis Online in  our entreprise
we have some  applications that we would like to add to our platform and thus allow a user to access applications by  consuming his credits.
I hope that is more clearer now
thanks for any idea or help
