How to add a 6th widget on the Dashboard theme on WAB?
1547
01-21-2020 09:25 AM
DanielaZuloaga
I'm using the Dashboard theme for a Web App, and it seems to only support a maximum of 5 widgets in the placeholders in the map area. However, I need to add a 6th widget. How can I add it? I also can't seem to be able to group widgets in here.
by Anonymous User
Not applicable
Hi Daniela Zuloaga‌, you may be interested in Web AppBuilder for ArcGIS (Developer Edition) - you can customize the app beginning with the Dashboard framework. Using ArcGIS Experience Builder you have more control over how many widgets are in the app too.
Hope that helps,
-Peter
by Anonymous User
Not applicable
Hope that helps,
-Peter
