How return all values/attributes of table using arcade?
1941
08-22-2022 07:33 AM
anonymous55
Hello
I have this code which return specific fields but right now I need to return all values. I can write all attribute in code but the table I refer has lots of fields. is it any way I can get all fields on table to use it in pop up in web map
var fips = $feature["parent_id"]
var dd = FeatureSetByName($map,
"Survey v2", ['age','gender','race'],False)
var fillterSur = "survey_id = @fips"
var cou = First(Filter(dd, fillterSur))
var popupTEXT = "Age: "
+Text(cou,'#,###')
var popupTEXT = "gender: "
+Text(cou,'#,###')
var popupTEXT = "race: "
+Text(cou,'#,###')
return popupTEXT
Tags (3)
JohannesLindner
var dd = FeatureSetByName($map, "Survey v2", ['age', 'gender', 'race'], false)
if(cou == null) { return "no survey found" }
var attributes = Dictionary(Text(cou))["attributes"]
var popup_lines = []
for(var a in attributes) {
    var line = `${a}: ${attributes[a]}`
    Push(popup_lines, line)
return Concatenate(popup_lines, TextFormatting.NewLine)
Have a great day!
Johannes
JohannesLindner
Something like this?
var attributes = Dictionary(Text($feature))["attributes"]
Have a great day!
Johannes
anonymous55
Thanks Sorry I am kinda new to this Arcade code
How can I combine your code with mine.
JohannesLindner
Have a great day!
Johannes
anonymous55
Thanks @JohannesLindner This is working fine but if I don't want to list  attributes and bring everything without writing because table has lots of fields
JohannesLindner
I'm not quite sure what your question is. I'm assuming you want to limit the fields that get printed. You can do that like so:
var print_fields = ["age", "gender", "race"]  // define the fields you want to print in the popup
for(var f in print_fields) {
    var a = print_fields[f]
Have a great day!
Johannes
